ddnguyen06
#1 Posted : 16 years ago
ddnguyen06
My electric dryer have no heat. I did check the heating elements and they are goods. please help.
richappy
#2 Posted : 16 years ago
richappy
Probably a bad thermal fuse located near the top of the heater assy. Just take the wires off, short them, and see if you have heat. If so, order the kit
AP3094244 comes with the fuse and overload thermostat.
ddnguyen06
#3 Posted : 16 years ago
ddnguyen06
I checked all the thermostat and thermal fuse are working fine and the continuity are goods. motor keep running even i open the dryer door it does not stop.
richappy
#4 Posted : 16 years ago
richappy
Check the power in the back, should be 230 volts. If ok, check the timer contacts for heat. Usually a heavy gauge yellow and black wires.
heating problems, no heat (Dryer Repair)
by ddnguyen06 16 years ago
