jojo1961
#1 Posted : Tuesday, July 7, 2009 4:38:11 AM(UTC)
jojo1961
We bought this microwave 3/25/08 when we were remodeling our kitchen. I use it often and have had no problems. I used in on Saturday, July 4th and it worked fine. Later that evening when I was reheating some things, it would not heat. Everything else works. The turntable revolves, the light comes on and it sounds like it is running but it will not heat. We have unplugged it and plugged it back in and tried to heat a bowl of water. Still nothing. Do you have any ideas?
#2 Posted : Tuesday, July 7, 2009 3:22:02 PM(UTC)
The problem could be a bad door switch or a bad control board. In order to perform the troubleshooting you have to have a simple multimeter.
Remove the microwave from the cabinet, remove the outer case and check the door switches for continuity as described in the Tech sheet.
If there is nothing wrong then disconnect the wires from the high voltage primary windings and check for 120 VAC between those wires while the control calls for heat and the door is closed.
If there is no proper voltage then the control board has to be replaced.
If there is 120 VAC then the magnetron is a culprit.
Post the results and we'll help you with the correct part numbers.
jojo1961
#3 Posted : Tuesday, July 7, 2009 6:12:46 PM(UTC)
jojo1961
Thanks for the info Gene! We will check the items you suggested and update you on our findings!
jojo1961
#4 Posted : Wednesday, July 8, 2009 6:43:40 PM(UTC)
jojo1961
I checked the voltage across the primary lines(wires where still connected to trans) of the transformer while calling for heat. 120 volts was present.
Is this a good indication that the heating unit is bad.
#5 Posted : Wednesday, July 8, 2009 8:30:28 PM(UTC)
The wires must be disconnected otherwise the test result is inaccurate.
christ_ja
#6 Posted : Thursday, July 9, 2009 9:39:23 AM(UTC)
christ_ja
Im having the same issue. I just checked the voltage between the primary lines when the unit is powered up and running and i have nothing. All three switches have continuity....Bad control board?
christ_ja
#7 Posted : Thursday, July 9, 2009 9:41:07 AM(UTC)
christ_ja
Ive also already replaced the magnetron and rectifier. Anything else i should look at before spending $130 on a new control board?
#8 Posted : Thursday, July 9, 2009 6:30:56 PM(UTC)
What is the complete model number of the microwave?
christ_ja
#9 Posted : Friday, July 10, 2009 7:55:09 AM(UTC)
christ_ja
Mine is a maytag MMV5186AAW. The power doesn't seem to be getting out of the control board to the transformer.
I think [/URL][URL="http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5171092"]this is the control board i need...
Problem with Whirlpool electric range (won't heat properly anymore) (Oven Repair (including Ranges and Cooktops))
by phillydee 4/20/2023 6:10:35 AM(UTC)
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool gas oven lights but won't heat to temperature (Oven Repair (including Ranges and Cooktops))
by mikepol2 10/28/2021 5:13:06 AM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
GE Microwave (JE1860BH04) won't heat AND table won't turn (Microwave Repair)
by CoryH 2/17/2021 6:45:11 AM(UTC)
Double Oven Won't Heat Back Up After Opening (Oven Repair (including Ranges and Cooktops))
by lamoureux.adam@hotmail.com 12/13/2020 11:44:10 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Maytag MGD9700SQ0 Won't Heat/Open Gas Valve (Dryer Repair)
by jpc315 11/9/2020 2:59:17 PM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Maytag Dryer *usually* won't heat (Dryer Repair)
by ab52 6/12/2020 12:20:59 PM(UTC)
GE dryer runs but won't heat up (Dryer Repair)
by bristles 5/5/2020 5:44:54 PM(UTC)
GE Cafe CT9050SH1SS won't heat to desired temperature (Oven Repair (including Ranges and Cooktops))
by gvfixit 4/19/2020 3:22:33 PM(UTC)
Outside element in dual element won't heat, even after replacing (Oven Repair (including Ranges and Cooktops))
by RyanSha 9/2/2019 8:11:47 AM(UTC)
Kenmore Electric Wall Oven 790.41003603 - Broil AND Bake elements won't heat (Oven Repair (including Ranges and Cooktops))
by acehigh21 7/28/2019 11:14:25 AM(UTC)
