Mary Turner
#1 Posted : Sunday, July 5, 2009 12:33:44 PM(UTC)
Mary Turner
Wash Cycle Will Not Start - F11 Code Flashes
sidfink43
#2 Posted : Monday, July 6, 2009 2:54:51 PM(UTC)
sidfink43
Hi Mary
If you will take off the bottom front panel (two screws) you will find a tech sheet and trouble shooting instructions.
Your machine has a computer control board which is the main brain, and a motor control board which as its name implies, manages the motor. Your error code says that the two boards are not talking to one another.
This may be a wiring problem (check for frayed wires or shorts) but more likely a failure of one of the boards. See if the troubleshooting helps you figure out which one, but if you have to make a guess I think it is more likely the motor control board.
Good luck, let us know what you find out.
F11 Error Code (Washer Repair)
by tonybravo845 2/20/2016 7:32:48 AM(UTC)
F11 Error Code on Whirlpool Duet Front Load Washer (Washer Repair)
by tdag 1/4/2015 7:53:29 PM(UTC)
Whirlpool F11 Error Code and Resolution (Washer Repair)
by ruahusker 2/6/2013 4:05:24 PM(UTC)
Whirlpool F11 error code (Washer Repair)
by byrdman59 2/18/2012 7:30:56 AM(UTC)
