badbikers
#1 Posted : Sunday, December 30, 2007 8:24:42 AM(UTC)
badbikers
:( I have a frontload washer purchased in feb of 03 it makes a terrible sound when drum is going around. Sounds like something is draging. When I took off the back and top nothing looks wrong. We already replaced the shocks and water pump about a year ago. We also had an Sears tech out and he says with just listening to the drum its the bearings going bad. About a 500 to 600 dollar fix! Is this something that we could do or not even worth it? Any suggestions? Also sears says that its from not using a low sudzing soap and that is why its not covered under the extended warranty. Thanks for some imput.
richappy
#2 Posted : Sunday, December 30, 2007 1:38:58 PM(UTC)
richappy
You can buy the rear shell assembly for about $250 plush shipping. There is a very good article on this at (www.applianceaid.com) ,good luck.
okbobcats
#3 Posted : Monday, December 31, 2007 4:50:45 AM(UTC)
okbobcats
It sound to me like the sears tech was trying to get out of work. Call again and ask for a different tech. If that doesn't work try cr. But I'm sure the different tech will order the parts. PS hide your soap and put a jug of h.e. soap on the the shelf.
Adunc
#4 Posted : Saturday, May 17, 2008 9:25:09 AM(UTC)
Adunc
I've gone to the website and haven't been able to locate the article.
