Snowcats
#1 Posted : Thursday, June 25, 2009 2:23:20 PM(UTC)
Snowcats
I Replaced the Igniter now have 3.5 amps. The burner comes on then the igniter fades out and the burner flame goes out.
With the oven set at 350 the preheat tone goes off with the oven at 225.
With the oven set at 400 the preheat tone goes off with the oven at 300.
Tried the temperature adjustment in the manual, did not change the oven temp by much. Which to try next Temp sensor or the controller?
Before the igniter was replaced some times the oven would work fine other times it could not make or hold temp.
Dan O.
#2 Posted : Thursday, June 25, 2009 8:33:38 PM(UTC)
Dan O.
That sounds normal.
Many newer ranges are programmed to stop preheat before the set temperature is reached. Manufacturer's claim a full preheat isn't needed (but might be partially to get better energy usage ratings?). I do not know how the control on your model is designed to act.
What is the actual temperature in the oven when set to 350 (or whatever) once it has fully reached the highest temperature it will get to (not just when the preheat signal goes off)?
What temperature does the control display at that time?
Quote:
Model Number: ARG7102
That model number is incomplete and we'd also need the unit's manufacturing (MF G) number to properly identify the appliance in question. It starts with the letter "P..." and is on the same tag as the model and serial number. If you need further assistance please post that information as well.
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Snowcats
#3 Posted : Friday, June 26, 2009 4:21:34 AM(UTC)
Snowcats
Full Model # ARG7102W P1143347NW
I think it is normal for the oven to sound preheated before reaching the full set temp. But the oven use to be little low then contitinue to raise to temp. The oven use to reach full temp. now it never reaches full set temp.
The oven temp is set by a knob and the display is only a clock the temps. I posted were from a oven thermometer being read through the window.
THe oven reached 300 set at 350 and reached 375 set at 400 The controll unit has a temp adjust feature to fine tune the oven it does not seam to change anything.
Dan O.
#4 Posted : Friday, June 26, 2009 9:47:05 AM(UTC)
Dan O.
Quote:
The oven reached 300 set at 350 and reached 375 set at 400
Than the oven temperature sensor may have become out of calibration with age or there might be a problem with the temperature reading circuit of the electronic control.
LINK > Amana ARG7102W Oven Temp. Sensor
LINK > How do I check an oven temperature sensor?
LINK > Amana ARG7102W/P1143347NW Electronic Control
Quote:
The controll has a temp adjust feature to fine tune the oven it does not seam to change anything.
At most such a calibration will usually only compensate +/-35°F. If out any more than that there is usually a defective component that would need to be replaced to correct the outage.
JMO
Dan O.
=D~~~~~~
Snowcats
#5 Posted : Saturday, June 27, 2009 3:43:36 AM(UTC)
Snowcats
Thank you Dan
I removed and checked the temp. sensor it checks ok heated to different levels. So it looks to be the control unit.
Thanks again for your help and time.
oven temp off (Oven Repair (including Ranges and Cooktops))
by laurieat 4/11/2013 3:00:20 PM(UTC)
Oven temp off 100 degrees (Oven Repair (including Ranges and Cooktops))
by S Brown 10/30/2008 6:44:37 AM(UTC)
Oven temp off by 50 degrees (Oven Repair (including Ranges and Cooktops))
by hs545 10/5/2007 1:54:33 AM(UTC)
