Skroela
#1 Posted : Thursday, June 25, 2009 4:49:32 AM(UTC)
Skroela
I was reheating coffee when the microwave caught fire!. I unplugged it, cleaned the mess. The fire was located on the right hand inside panel, on the rack holder. When I plugged it in, the unit works continuously, lights on and it looks like a thunder storm inside, even with the door open it does not stop. is it possible to repair this? can I disable the microwave and continue using the fan and the lights? thank you for your help.
#2 Posted : Thursday, June 25, 2009 5:05:57 PM(UTC)
Remove the top grill and open the control panel. Check all door switches and inspect the control board for a burned spots. Post the results.
Here are the breakdown diagrams and Replacement parts for GE JVM1850WD001 | AppliancePartsPros.com
Skroela
#3 Posted : Saturday, June 27, 2009 11:07:25 AM(UTC)
Skroela
Thanks for your prompt reply!. I removed the grill and check the board. There's a burn spot on the board nothing big just a small spot on the conector CN08 SENSOR, everything else looks OK.
#4 Posted : Saturday, June 27, 2009 1:55:00 PM(UTC)
Possible the gas sensor (#62 on the diagram) is damaged as well as the control board.
Skroela
#5 Posted : Saturday, June 27, 2009 3:15:23 PM(UTC)
Skroela
Thank you.
I think it would be better just to buy a new one. One last question, is it difficult to install this type of microwave?, the guy at the store is charging $200. Is it something I can do myself?
Thanks again.
#6 Posted : Saturday, June 27, 2009 6:38:19 PM(UTC)
A new microwave comes with the installation instructions. If you know how to handle a simple hand tools and you have a good drill then you can do it.
Guest (5)
