willp3
#1 Posted : Monday, October 1, 2007 10:46:53 AM(UTC)
willp3
Our washer has the following problem. Here are the symptoms:
-Washer does not spin but it does pump water
-The drive belt is slipping and burning
-I removed the agitator (the plastic part in the middle of the tub) and there was nothing jammed in there.
-i put a new belt on and no change
-when i took off belt and ran it the drive motor spun
Follow-up question: Is this part serviceable? Is it an all or nothing
richappy
#2 Posted : Tuesday, October 2, 2007 2:06:21 AM(UTC)
richappy
Check your model#.
willp3
#3 Posted : Tuesday, October 2, 2007 1:45:26 PM(UTC)
willp3
where can i find it i have a magic chef electric washer and the only number i found under the hood isnt popping up anywhere
richappy
#4 Posted : Tuesday, October 2, 2007 5:04:30 PM(UTC)
richappy
Remove belt and try to find cause of jam. Turn pump pulley and tranny pulley both ways. If jammed in spin direction you might have something caught in tub.Shine a light in tub and check for something. If everything is ok, you just might have the wrong belt. Washer belts are made to act as a clutch, ie. the wrong belt will cause problems like this.
beanjamin55@yahoo.com
#5 Posted : Saturday, October 6, 2007 12:55:51 PM(UTC)
did you figure it out? I have similar problem with my frigidaire washer,exact symptoms
aimee
#6 Posted : Saturday, November 3, 2007 1:23:35 PM(UTC)
aimee
my washer is having similiar issues. the belt squealed , then smoked and smelled and now i cant move the agitator
ntucker
#7 Posted : Saturday, April 4, 2009 5:31:57 PM(UTC)
ntucker
Did you find out what was wrong with it, I am having the same problems and would like to know how you fixed it??
ccroy
#8 Posted : Monday, June 22, 2009 6:29:56 PM(UTC)
ccroy
:):D
Awesome advice! I have a GE stackable washer/dryer combo that had this exact problem! Burning smell, tub wouldn't move.
For my job I use small screwdrivers that can clip in my pocket like a pen. One had jammed in the tub!:o Better job checking my pockets from now on.
My unit is ~ 15 years old. The belt now looks glazed and just generally old. Since I have the washer open I think I will order a replacement belt.
Is this a good idea? Seems like I'm due.
Thanks,
Chris
richappy
#9 Posted : Tuesday, June 23, 2009 12:45:48 AM(UTC)
richappy
For the Frigidaire washer, they have a sad history of partially or fully jamming of the tranny, just check.
Guest (5)
