2 Pages<12
slyda
#11 Posted : Friday, July 4, 2008 10:21:33 AM(UTC)
slyda
Alright Cool.. before this Main Board problem i noticed that when the doors are closed the fan would run and when the door is opened the fan would stop but now it runs almost all the time, also it does not run as fast as it used to.. is the board an updated unit? or is it something with the evaporator fan,but like you said it will run 80% of the time which i dont mind as long as its working which i see it is fresh food is currently set on 3 and freezer is set on 5,also the ice tray is starting to get filled up with ice, i left a thermometer in the fresh food section for about 5 mins and got a reading of about 42 degrees.
abadfish66
#12 Posted : Friday, July 4, 2008 7:13:35 PM(UTC)
abadfish66
Your good to go, nothing you are telling me is abnormal about the operation of your fridge after the repair. Your temps are fine, the fan is fine. The fan will changed speeds, and does change speeds, you may only notice it on medium, but there are 4 speeds to that fan, slow, medium, high and superhigh, and will run at different speeds depending on many variables going on with the fridge like door openings, food load, defrost, prechill, dwell, outside ambient temp, etc... I could go on and on but I think you get my point.
slyda
#13 Posted : Friday, July 4, 2008 7:34:36 PM(UTC)
slyda
LOL alright, i guess the problem is fixed then, thanks alot for your troubleshooting skills in helping me resolve this issue badfish i appreciate it.Thanks Again !
abadfish66
#14 Posted : Friday, July 4, 2008 10:18:33 PM(UTC)
abadfish66
Let me know if you need anything else :)
slyda
#15 Posted : Thursday, July 10, 2008 5:27:53 PM(UTC)
slyda
ok Sorry To bother you again badfish.. its july 10th.. i have a serious problem with the fridge and freezer now, its not cooling again, the fan is spinning very very very slow i can barely hear the Motor running and the ice is melting all over the freezer, i removed all the ice and turned the fridge and freezer on 9 to retain coolness,what can the problem be? can it be the fan this time? i hope it is not the main board again, if it is why does it keep failing? immediate help is needed please!! thanks.
Guest (12)
2 Pages<12
