2 Pages<12
dgk1173
#11 Posted : Wednesday, June 25, 2008 12:17:58 PM(UTC)
dgk1173
No Change. I think the drain solenoid may be frozen in the down position probably due to rust. I have never seen it in the up position. The movements I mentioned earlier were less than a 1/8th of an inch and not of the solenoid but of the plastic lever arm which is moving when the inlet water is bieng turned on and off. Does this make sense. I cannot move the solenoid piston up or down or sideways, it is rusted frozen. I will try some wd-40 and see if I can loosen it.
2 Pages<12
