In need of some HELP! Had a code f2 and Sud. Ran a DIAGNOSTIC TEST all cycles checked out. • Ran the unit through a Rinse/ Spin cycle then a
Normal cycle without adding any detergent. This should have cleared the unit of the excess detergent. • Checked the drain hose and make sure it is not plugged or kinked • Checked Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU) • Checked/ Cleaned Drain Pump Filter of foreign objects • Check Drain Pump • Check the Pressure Switch • Check CCU Still had codes! I replaced the pressure switch, code still showed. I replaced the drain pump, code still showed. I took off Pressure Tube Connector from tub and checked o-ring and to see if it needed cleaning. Reinstalled, code still there. I took off the Eco Valve and cleaned. Reinstalled, code still there. All connection were tested and checked to see if there was a break. Reinstalled, code still there. The MOTOR CONTROL UNIT was replaced 6 months ago. Need some input Please!!! Is there a way to test the CENTRAL CONTROL UNIT ???
