kts532
#1 Posted : Saturday, April 26, 2008 3:53:35 PM(UTC)
kts532
Is the plastic nut at the bottom of the drum left or right thread. need to replace tub bearing.
richappy
#2 Posted : Saturday, April 26, 2008 4:22:26 PM(UTC)
richappy
It is an aluminum alloy nut, left hand thread. I use the special spanner wrench to get it off. The web site www.applianceaid.com has info for this. Also, you must replace the seal, there is a groove in the tranny to facilitate driving the old bearing out with a punch.
stubborn tub nut, leaking tub, loud noise (Washer Repair)
by stubborn nut 10/24/2014 5:14:20 PM(UTC)
Tub nut / Univesal joint (Washer Repair)
by andbat 12/18/2011 7:01:19 AM(UTC)
How to remove washer tub nut (Washer Repair)
by Biffspagnutz 5/11/2011 11:54:20 AM(UTC)
how to to remove tub nut/seal admiral washer (Washer Repair)
by heidmann1 10/7/2009 9:16:40 AM(UTC)
Removing GE tub nut (Washer Repair)
by richappy 1/2/2008 9:16:32 AM(UTC)
