The warm and hot water cycles work fine. Good flow. The cold water setting on a wash or rinse is extremely slow. Barely any water coming into the tank. Anyone have any idea what the problem might be?
If there is nothing wrong with the pressure in the supply line then the problem is a clogged water inlet valve. - The part number for the water inlet valve is AP3094541 Here are the complete instructions on how to replace the water inlet valve. Here are the break down diagrams for the Whirlpool washer Model LSR7233DQ0Gene.
