Fieldwolf
#1 Posted : Saturday, December 4, 2021 8:37:58 PM(UTC)
Fieldwolf
Hi,
I had a self-cleaning cycle issue (blown fuse). I have replaced the fuse, which brought the oven back to life, but both my wife and I are noticing some weird behavior:
  • It takes it longer to preheat
  • Once in a while it just will get stuck in Preheating mode, 30-40 degrees under desired temp. Switching to “convect bake” for preheating seems to solve it
  • It also seems like it doesn’t hold the desired temperature well (goes down 40-50 degrees from the target temp), but I’m not sure how to test that
Are there other parts I should have replaced after a self clean? Any other ideas of what could be wrong here?
Thank you
