2 Pages<12
Tom Spurlock
#11 Posted : Tuesday, November 30, 2021 9:10:02 AM(UTC)
Guest
Originally Posted by: wpollock Go to Quoted Post
Tested all switches in place and the middle switch tested bad. Removed the switch door bracket and with the switch still in place the actuator tab would not click as would the tabs on the top and bottom switches. Removed the switch and after a few times depressing and releasing the tab it started clicking again. The switch now tests to be good but will replace the switch. Is there a way to include jpeg images in a reply?
I had the same problem. I replaced all 3 switches since I had it apart, and the total cost was $35. Later I opened up the switch to see how bad they were. The top two black switches had considerable contact wear from sparking and arcing, leaving lots of soot and carbon on the switch walls. The bottom gray switch was like new when I took it apart, it probably didn't need replaced, but for $10 it was no big deal.
My situation was the switches were intermittent. The switches all tested good with a meter. During use, the contacts would occasionally stick apparently, causing the breaker to trip. FYI, if you have a 20Amp house breaker feeding the microwave, it's likely the microwave fuse inside the microwave will blow. That fuse is accessible without taking the microwave out by removing the vent cover above the door, exposing the fuse. Two screws on the top allows the removal, but it's tricky. However, replacing the fuse will likely result in another blown fuse without replacing the problem switches.
2 Pages<12
