Goober923
#1 Posted : Friday, July 14, 2017 9:43:15 AM(UTC)
Goober923
Washer will not fill with water on normal and heavy. Works on all other settings. Unplugged for 10 minutes and worked for 1 cycle and quit again. Tried to reset circuit board and that didn't help. Has no fault codes. Any suggestions.
PNWDrew
#2 Posted : Friday, July 14, 2017 10:07:05 PM(UTC)
PNWDrew
For unknown reasons Samsung front loaders will sometimes take a long time sensing. How long have you let it run after starting? I've seen 7-8 min of sensing when other times it fills almost immediately.
Quick test on these is easy to enter. Press spin, soil, and power at the same time and it will go into test mode. Rotate knob until it says test. It won't open a valve unless door us locked, I think its the button next to temp that locks it. Once it's locked every time you press the temp key you'll open a different valve. Verify all valves work. It'll max out at some point and you'll need to find which button drains it. It'll be to the right of the temp key. Or you can turn knob one click to spin and it'll drain first. There may be a tech sheet taped to the back to help in what I can't remember.
Samsung Washer No Agitation or Spin (Washer Repair)
by amappliancewi 2/7/2024 10:24:03 AM(UTC)
Samsung washer balancing (Washer Repair)
by AF96 3/18/2023 8:50:39 AM(UTC)
SAMSUNG WASHER CODE 9e1 (Washer Repair)
by Vsparaney 12/14/2022 9:41:28 PM(UTC)
Samsung Washer WA50F9A8DSP/A2-01 (Washer Repair)
by Vsparaney 12/13/2022 10:05:08 PM(UTC)
Samsung Washer not going into fast spin (Washer Repair)
by Guest 9/13/2022 10:10:14 AM(UTC)
Samsung Washer Spin Racket - Not the Bearing or Shock! (Washer Repair)
by lothian.mcadam 8/14/2022 7:15:24 PM(UTC)
Samsung washer won't spin (Washer Repair)
by Guest 1/8/2022 10:56:39 AM(UTC)
Samsung washer not working (Washer Repair)
by ermannojdangelo@gmail.com 9/11/2021 10:36:05 AM(UTC)
samsung washer drains detergent (Washer Repair)
by Guest 7/30/2021 10:38:39 AM(UTC)
Samsung Washer WF42H5400AF/A2 (General Talk)
by Chops 1/16/2021 8:51:39 AM(UTC)
Samsung washer wf50k7500av/a2 (Washer Repair)
by Kian010 9/29/2020 8:57:15 PM(UTC)
Samsung washer fills even after turn off (Washer Repair)
by bpaulik 6/4/2020 4:42:14 AM(UTC)
Samsung washer shock bearing (Washer Repair)
by Jaslikow 5/30/2020 3:43:53 PM(UTC)
Samsung Washer no Power (Washer Repair)
by SalmanUSA 4/21/2020 8:50:15 PM(UTC)
Samsung Washer Making Noise (Washer Repair)
by Bob_Bob356 4/21/2020 10:13:29 AM(UTC)
