E: KENMORE WASHER - Model 11022894100 following Steve's "Washer Repair- Replacing the Clutch Assembly (Whir_medium.mp4) during reassembly a part fell out on the left side. It looks" like" a brass nail, 1-1.5 in. long, about 5/16 in in diameter with a "flat side"and a pointed end with a small hole in it. I can not find it on any parts diagram .?? What is it, where does it go? The Video IS excellent! jRp@49C4 attached the following image(s):
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
That interestingly enough is one of three shipping pins used to hold the tub support still on the base frame. Once delivered and installed it is removed and falls into a little plastic cup on the base frame.
I kinda thought something like that but did not see the" plastic cup " THANKS ( The repair went excellently!!! :) ;-)
