The washer tub is leaning to the right and slightly forward. It is very loud and is starting to move around the floor. I changed the 3 suspension springs and the balancing spring. Nothing changed after changing the springs. What else could the issue be? Possibly drive block??
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
All springs are still in place. The three suspension and the balancing spring.
After looking at it closer this morning, the front right metal leg has a white powder substance. This is the side it's leaning to. I'm guessing the suspension pad is badand wore down. I'm going to order a set of 13 and 15. Skate plate itself looks fine.
