Washer won't go into high spin at end of washing cycle. No codes show at any time. If I do error history and diagnostic test F 21 code shows under history. I replaced Drain Pump and Motor Assy. Checked drain hose and drain (ok). During diagnostic test washer goes thru test ok and does high spin ok. Tried to get service manual for this model but no one has one.
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
Hose is clear, nothing in it. I need a service repair manual for this model, MHWE400WW00, can't locate one online or any where else, in order to test components. Thanks for the help.
