mmela
#1 Posted : Monday, August 1, 2016 6:18:52 PM(UTC)
mmela
The led light on the motor blinks as it is suppose to. I turn on the washer and the shift disengages from the drive. So I have performed the field service mode test. It doesn't agitate or spin. I disconnected the wires leading to the shift circuit and performed the test again. it still did not agitate or spin. That leaves the Inverter motor assembly, Yes?
brobriffin
#2 Posted : Thursday, August 4, 2016 3:15:56 PM(UTC)
brobriffin
Man
Check to see if you are getting 120 to the motor via the dark blue wire in normal high speed mode.
