The led light on the motor blinks as it is suppose to. I turn on the washer and the shift disengages from the drive. So I have performed the field service mode test. It doesn't agitate or spin. I disconnected the wires leading to the shift circuit and performed the test again. it still did not agitate or spin. That leaves the Inverter motor assembly, Yes?
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
Check to see if you are getting 120 to the motor via the dark blue wire in normal high speed mode.
