Dryer runs but no heat. How can you just tell if the element is bad or could something else cause the element to not be coming on.
Heater checking: Measure it with a meter of ten you can see the break in the element
Other causes: No 240 volts Thermal fuse blown One of the thermostat,s blown Timer contact blown Motor's centrifugal switch blown |
THIS FORUM IS DEAD!!!!!!! |
