Turns out the solenoid fill switch was bad. Tested good with an ohmmeter, but clogged inside with rust, lime, and scale. All is well now. Thanks again for the great forum!
You are welcome, though I just volunteer some time here. It is AppliancePartsPros that should get the credit as they sponsor this forum and do not require participants to buy from them.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause. |
THIS FORUM IS DEAD!!!!!!! |
