rjcarrell
#1 Posted : Thursday, July 23, 2015 5:17:27 AM(UTC)
rjcarrell
Center divider strip between doors is extremely hot. Unit cooling fine on both sides but runs almost continually. Cleaned coils per directions in manual best I could, no help.
#2 Posted : Thursday, July 23, 2015 7:47:00 AM(UTC)
Did you check that the condenser/compressor fan was running.
And that it is blowing correctly.
I would also check the fan blades as dirty blades can drastically reduce air flow.
Also check that the rear cover vents and the kick plate vents are clean.
David West
#3 Posted : Thursday, July 23, 2015 12:59:23 PM(UTC)
David West
read this: How to Fix a Whirlpool & KitchenAid W10219463 / 2307028 Control Board for $6 - SteveJenkins.com
If you're handy with a screwdriver & soldering iron, you can fix it yourself -- I did.
Kitchenaid Fridge Longer Cold (Refrigerator & Freezer Repair)
by FridgeHelpPlease 1/17/2024 7:18:43 AM(UTC)
KitchenAid fridge KSCS25FTMS02 ice maker stops (Refrigerator & Freezer Repair)
by dj_k2000 3/16/2023 7:38:08 AM(UTC)
KitchenAid Fridge ( Model kbsd602ess01) won't dispense crushed ice (Refrigerator & Freezer Repair)
by Manuel Ribeiro 2/15/2023 6:44:32 AM(UTC)
KitchenAid Fridge has frost in the freezer (Refrigerator & Freezer Repair)
by Guest 1/19/2023 9:37:38 PM(UTC)
Kitchenaid fridge too cold. Freezer OK. (Refrigerator & Freezer Repair)
by Dgclarkson 1/23/2021 1:39:46 PM(UTC)
Kitchenaid Fridge Lights off Not dispensing Ice/Water (Refrigerator & Freezer Repair)
by George1234 10/14/2019 11:30:17 AM(UTC)
Kitchenaid Fridge KSCS25INSS00 (Refrigerator & Freezer Repair)
by mickkassem 4/30/2019 3:05:03 PM(UTC)
Kitchenaid Fridge Lights, Ice, and Water not working (Refrigerator & Freezer Repair)
by Biglurr54 7/11/2017 5:15:48 AM(UTC)
Kitchenaid Fridge with lots of problems (Refrigerator & Freezer Repair)
by zumpa21 12/1/2015 6:58:28 AM(UTC)
KSCS25FTMS - Kitchenaid Fridge Lights/IceMaker Not Working - But Fridge/Freezer Work (Refrigerator & Freezer Repair)
by cgsauer 4/7/2015 5:25:13 AM(UTC)
Kitchenaid Fridge - Controls not workin (Refrigerator & Freezer Repair)
by hebertpl 11/27/2013 12:25:17 PM(UTC)
Kitchenaid Fridge Trips GFI (Refrigerator & Freezer Repair)
by ahursh 11/20/2012 10:33:50 AM(UTC)
Kitchenaid Fridge Freezer fault (Refrigerator & Freezer Repair)
by davesmckee 10/20/2012 2:18:01 AM(UTC)
Kitchenaid Fridge Light Not Working (Refrigerator & Freezer Repair)
by RowRow 7/25/2012 8:16:48 AM(UTC)
Kitchenaid Fridge Icemaker not working (Refrigerator & Freezer Repair)
by lancecowell 7/12/2012 4:04:09 PM(UTC)
