stubborn nut
#1 Posted : Friday, October 24, 2014 5:14:20 PM(UTC)
stubborn nut
Have a GE top loader, loud noise during agitation, spin. Leaks down around pulley bearing area. Have tub nut spanner wrench. Tried to loosen clockwise. Wouldn't loosen w/ 3 days of penetrating oil. Today I thought it broke loose. Instead the entire shaft is turning. Help!
Thanks Stubborn Nut
sidfink43
#2 Posted : Saturday, October 25, 2014 3:36:27 PM(UTC)
sidfink43
I am fearful that the leak has let water into the mode shifter assembly in which case I think given your problem getting the nut off that a new machine is the best option here.
Sorry not to have a better recommendation.
