I don't really hear any click when I start the dryer. And for sure there is no second click.
Then your gas valves are not working. If the coils are good, flame sensor is opening, then I would replace the valve assembly.
Eric
Hi, I just double-checked it. There is no click at all except from the motor. But nothing from the valve or coils or either of the two switches. I don't see anything in the parts list called valve assembly. Is that the burner or dryer gas valve coil kit? The coils I have already replaced.
Hi, I cannot find the gas valve on this website. I would be happy to purchase it. I did go out and buy a flame sensor and installed it but that didn't fix the problem. I think the valve is the last thing. Is it possible to be in the control panel at the top of the machine?
I provided the link in post number 10.
Thanks so much for all of your help!
