There is a plastic splined coupling at the bottom of the tub. That can get "gunked up" and cause poor floating, too. That tub should float easily once filled.
Originally Posted by: Appliance Ninja ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Okay, you likely have an issue with the tub not floating as the water level rises. There may be an article of clothing or something between the two tubs, not allowing the tub to float. Can you remove the inner tub to inspect? I'm having trouble removing the inner tub. I purchased a spanner wrench for "Maytag" and that thing was way too big. TB123A. There is some kind of "nut" with 4 "grooves" that I need to remove to take out & I've had absolutely no luck. Can someone please let me know what I can use to take this thing out. I've tried everything. Screwdrivers, wrenches, pipe wrenches, etc.
