Unit 12-13 years old. Lights go on. No cooling in either r/f. No motor, fan, ice machine sounds for last 24 hours. Guest in my home said it stopped several days ago, restarted on own and then stopped again after a couple days.
I've replaced a capacitor in years past. Minimal handyman skills. Does this sound like something that a novice can fix (like the capacitor / restart module). Not sure how long this appliance should last.
Here are your parts Parts for Whirlpool ED25TEXHW00 Refrigerator - AppliancePartsPros.comSee the attachment for the tech sheet. Try turning the thermostat up/down a bit to see if it fires up. If this does nothing it could be that you are stuck in a defrost cycle. With a flat screwdriver turn the defrost timer (item 6 in the Control Parts section) cam. It will only turn in one direction. Usually there is a hole in the cover that will let you do this without any dis-assembly. Make sure that the thermostat is not at off. If it fires up replace the timer. |
THIS FORUM IS DEAD!!!!!!! |
