heidmann1
#1 Posted : Wednesday, October 7, 2009 9:16:40 AM(UTC)
heidmann1
I am trying to remove the transmission and the seal/nut under the agitator. BYt i guess you need to turn it counterclockwise to remove it. it has plastic tabs all around that you turn it by but it is really tight and I already broke 2 tabs off trying to get tit off? is there a special tool that fits into all these notches to remove? where do I get on if so? Thanks
sidfink43
#2 Posted : Thursday, October 8, 2009 3:09:11 PM(UTC)
sidfink43
See if this Maytag tech bulletin doesn't help you.
http://www.servicematters.com/m...rary/docs/TDL-0086-B.pdf
Good luck
