carl-761
#1 Posted : 12 years ago
carl-761
The fridge was working good but the freezer was not freezing ice cream every thing else ok. Now everything has melted in freezer and the fridge is getting warm to. The compresser is running the fan is running what could it be thank you for your time.
#2 Posted : 12 years ago
Parts for Frigidaire FRS6R4EWC Refrigerator - AppliancePartsPros.com
First confirm that the compressor is running all the time other than when the unit goes through a defrost cycle.
You can usually hear it but also should be able to feel it vibrating.
Is the fan you say is running the evaporator/freezer fan or the condenser/compressor fan?
Confirm that the evaporator fan is running.
If it is running all the time, remove the cover in the freezer so you can inspect the evaporator coils.
If they are heavily iced/frosted over you have a defrost problem.
If there is no frost or frost in just one area (usually where the freon enters the coils) then you have a sealed system problem and it will be an expensive repair.
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 10 months ago
Samsung Refrigerator Freezer Model #FJ24J9960S4/AA (Refrigerator & Freezer Repair)
by macdav2022 2 years ago
Refrigerator freezer either too cold or too warm, running continually (Refrigerator & Freezer Repair)
by coolforcats 2 years ago
1985 Kenmore 18 refrigerator freezer went warm recently (Refrigerator & Freezer Repair)
by Guest 3 years ago
Whirlpool Refrigerator Freezer Coils Icing up (Refrigerator & Freezer Repair)
by aarrington 3 years ago
Both refrigerator freezer and cabinet below freezing (Refrigerator & Freezer Repair)
Samsung French Door Refrigerator freezer not cold enough (Refrigerator & Freezer Repair)
by Sh@wn 3 years ago
KFIS29BBMS03 KitchenAid Refrigerator freezer only gets to 17 degrees, Fridge seems okay at 38 (Refrigerator & Freezer Repair)
by JCohen8008 4 years ago
Whirlpool Refrigerator Freezer Section Intermittently Not Cooling or Making Ice (Refrigerator & Freezer Repair)
by dreeves1822 4 years ago
GX2FHDXVB00 whirlpool refrigerator freezer not freezing (Refrigerator & Freezer Repair)
by Nwhe54 4 years ago
Sumsung refrigerator freezer problem (Refrigerator & Freezer Repair)
by DRJHNJHNSN 5 years ago
Viking 48" refrigerator freezer getting too cold (Refrigerator & Freezer Repair)
by nmunn 6 years ago
GE side by side refrigerator freezer not cooling (Refrigerator & Freezer Repair)
by ReddogRudy 7 years ago
GE Refrigerator freezer and food not cold enough (Refrigerator & Freezer Repair)
by Jerrysing 8 years ago
Frigidair refrigerator freezer cold refrigerator warm. (Refrigerator & Freezer Repair)
by Dennypccc1 8 years ago
