2 Pages<12
HVACrepair
#11 Posted : Saturday, November 21, 2015 9:09:42 AM(UTC)
HVACrepair
Its problem can be solved by full tuning of this machine, one or more times blower service can b also give some more satisfaction. Its air pipes are also may be in odd state, those pipes would also be repairable.
HVACrepair
#12 Posted : Tuesday, November 24, 2015 9:15:01 AM(UTC)
HVACrepair
heating furnace repair
balperi
#13 Posted : Tuesday, November 24, 2015 10:14:32 AM(UTC)
balperi
interesting thread, I too was having the same problem UserPostedImage
Patrick_Stevenson
#14 Posted : Tuesday, January 5, 2016 1:33:56 AM(UTC)
Patrick_Stevenson
I strongly advise you not to DIY as if you do something that should not be done will cause more trouble than what you are already trying to fix. I suggest contacting any repair company such as Domestic Services and ask them to come have a look. Good luck with your AC repair.
tinasingh
#15 Posted : Thursday, March 15, 2018 2:14:32 AM(UTC)
tinasingh
You have to try setting the thermostat fan switch to the "on" position. Feel for air coming out of the vents. If it is in the air conditioning mode, check for ice around the evaporator coil and on the refrigerant lines at the indoor unit. ... If the fan isn't working, that can cause the coil to freeze. I did same thing when i face same problem and take a help from air conditioner dealers.
2 Pages<12
