Originally Posted by: denman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) [COLOR="Blue"]Any thoughts?[/COLOR] Sounds like the fan is toast. I would replace it.
Not sure about the damper. If it is open then you probably will not feel anything. Try going to the Sears parts site. It should help you visualize how this thing is put together. Hi D. I've gone to ******************************** and see the body, misc. locations, etc.... I've checked all the images, and the do not show the ducting up the back of the unit at all. Have you got an image that does? Never mind. I found what appears (the seller is claiming it is) to be the service manual for the 596.75504400 freddie.
Hi D. According to what I've found, and have read, this is the manual that's claimed to be the tech manual for the Amana version of my kenmore freddie. According to a post from Appliantology, the 596 series of the Kenmore refrigerators were made by Amana. ManualWho Makes Freddies
Hi. Just wanted to drop back in to close this out. It appears that my fan inside the back of the freezer was bad. The heater checked out good, as did the defroster. I talked with a local appliance tech and he said that as only the tops of the coils were icing over, the fan is the problem.
I replaced my fan, and so far...... my freddie is back in business! Yea.....!!!!! :D :D :D :D :D :D :D :D :D :D :D :cool: :cool: :cool: :cool: :cool: :cool: :cool:
