2 Pages<12
Joe / APP Team
#11 Posted : Friday, April 12, 2013 6:28:25 AM(UTC)
Joe / APP Team
Originally Posted by: GaryDZ Go to Quoted Post
New question about the refrig.... So originally it was running too cold. Set at the highest temp.... still freezing soda---seldom used. door oped once ever few days.
Now that we are there every day.... set at the coldest level, it is only cooling to about 52 degrees F?
I have turned off the refrig at the breaker.... and turned it back on after 90 sec. Any ideas what to try? I feel like Goldie Locks--- too cold.... too warm.
Just moved into the house budget is tight.
Gary,Try this with the refrigerator. Model PSI23NGMBBB
Move the refrigerator out and remove power to the machine, remove the compressor compartment cover, and vacuum all the lint, dust etc. from the condenser coil, fan and blade, also clean the surrounding area, kick plate grille,etc. Put the refrigerator back, reset both the controls to mid range (5) and let the unit run and cycle for 24 hours, then check the temperature. Also, (if equipped) turn OFF the "custom cool" bin control, until the temperatures equalize. The controls set at mid range should give you temperatures of 0 dgrs in the freezer and 38 dgrs (+/- 2 dgrs) in the refrigerator.
The microwave, is a product we have little to no information on, but based on your post information, the display would be the place to start. You would want to contact the manufacturer for any service or parts information you may need.
2 Pages<12
