2 Pages<12
mrs9693nj
#11 Posted : Monday, April 1, 2013 1:31:44 PM(UTC)
mrs9693nj
richappy,
Thanks for your latest reply, I'm headed home from work soon and I will probably switch the boards tonight...but I have to ask, not because I question your knowledge (your the pro I'm the DIY'er needing the help) I'm asking just so I can understand why?
Why do I have to use the new board now that the one wire is clipped?
What am I risking? Since to the untrained DIY'er it appears to be working.
What is the damage I could be doing?
Thanks again richappy, youv'e been very helpful (patient too!)
Mark
richappy
#12 Posted : Monday, April 1, 2013 1:37:03 PM(UTC)
richappy
Apparently the thermistor wiring is diffent for the new board, so once the wire is clipped, using the old board will result in improper cooling in the fridg.
mrs9693nj
#13 Posted : Monday, April 1, 2013 1:53:34 PM(UTC)
mrs9693nj
that makes sense, so the longer I leave it this way the more likely something else goes wrong...
so what are the chances that I re-attach the clipped wire and keep the old baord in that things work right?
I'm being flat honest with you, strapped finances, more repairs to other things still needed so I'm trying to find wiggle room where I can...but I don't want to cheap myself into a bigger more expensive hole either.
Thanks again!
Mark
2 Pages<12
