2 Pages<12
mokitag
#11 Posted : Thursday, December 27, 2012 1:52:32 PM(UTC)
mokitag
Hello everyone. Ah ok cause I couldn't find anything for my kind of agitator. I checked the coupler and there are no cracks in it or anything. The top half of the agitator rotates one way but not the other so that's ok. When the bottom half was on the coupler, it could rotate easily both ways so I'm going to install it back on and maybe it just came loose and needed to be pushed down more. If that is all there is, at least it gave me a chance to give it a good cleaning. If it doesn't work, I will be back to ask more questions.
Thank you kindly for your responses. :)
Moki :)
mokitag
#12 Posted : Thursday, December 27, 2012 2:09:17 PM(UTC)
mokitag
Hello again. Well I tried to screw the coupler back on and put the screw and nut as tight as I could. What I see is the coupler moves freely clockwise and counter clockwise. Should this be happening? I want to make sure before I put the agitator back on. I put the coupler down as far as it would go. Thank you for your help again.
Moki :)
fairbank56
#13 Posted : Thursday, December 27, 2012 2:55:57 PM(UTC)
fairbank56
No, it should not rotate freely. Either the internal splines of the coupler are stripped or the agitator shaft is rotating freely which means the transmission is bad. Try rotating the agitator shaft by hand with the coupler off. You should not be able to do so. I am assuming this is a GE T-style washer, I'm not finding much information on the model number given. Hotpoint is made by GE. Can you provide a pic of the lower part of the washer with the front panel removed?
Eric
mokitag
#14 Posted : Thursday, December 27, 2012 3:05:06 PM(UTC)
mokitag
Hello Eric
I tried moving the shaft without the coupler attached and it doesn't move at all in either way. As you said, probably the splines are worn off. I live in Quebec, Canada so I guess I'll have to search around for a new coupler. When I have it screwed on, it moves either way and I knew that wasn't right.
I checked on the net as well and can't find anything at all for my model but I can bring the pamphlet that came with the machine with the model number and the used coupler. I cleaned the shaft grooves as well with a brush to make sure that there is no residue remaining.
Moki :)
mokitag
#15 Posted : Monday, December 31, 2012 11:32:46 AM(UTC)
mokitag
Hello everyone. I got my agitator coupling today and installed it on the washer and I'm doing a load. The only thing is that the agitator is a little loose on the coupling. The coupling is tight although. I'm wondering if it's because the agitator teeth stretched toward the years making a bit looser on the coupling. It is well secured and pressed down as per your videos and instructions. It wabbles a little. I guess if there is no solution to this, I'll have to leave it this way. If you have a little solution to this, I'd sure like to hear it. The part is the exact same part as the other one was and fits perfectly.
Thank you from Moki :)
fairbank56
#16 Posted : Monday, December 31, 2012 12:17:19 PM(UTC)
fairbank56
It's normal for the agitator to wobble a bit. If it's really bad, all you can do is replace the agitator.
Eric
mokitag
#17 Posted : Monday, December 31, 2012 1:49:49 PM(UTC)
mokitag
Hi Eric. Thank you and I did think of that. I will see how it goes. I am wondering if a loose agitator will affect the transmission if I don't replace the agitator??
Guest (10)
Removing Maytag agitator (Washer Repair)
by Guest 3/30/2024 5:55:35 PM(UTC)
Maytag topload agitator (Washer Repair)
by Guest 1/30/2024 7:23:54 AM(UTC)
GE top load with agitator - drum is free spinning (Washer Repair)
by JLS79 12/18/2023 8:21:30 AM(UTC)
Maytag Bravos Washer - Agitator spins fast/Drums spins slow (Washer Repair)
by JDugdale 8/29/2023 9:04:08 PM(UTC)
oil leaking under agitator into the washing drum (Washer Repair)
by sarte 8/1/2023 8:16:28 AM(UTC)
Beware when buying Agitator WPW1011020 (Washer Repair)
by Guest 7/18/2023 3:49:04 PM(UTC)
Should basket spin with lower agitator? (Washer Repair)
by bdollar 6/2/2023 4:44:56 PM(UTC)
Frigidaire Gallery Model GLWS1349AS0 Agitator Will Not Come Out (Washer Repair)
by Techowl 1/23/2023 10:39:56 AM(UTC)
My agitator bolt will not come out (Washer Repair)
by Guest 8/14/2022 4:47:19 PM(UTC)
GE Hydro Wave Quiet Agitator Wash System Lint Screen? (Washer Repair)
by Alphonse 3/13/2022 1:50:28 PM(UTC)
Whirlpool agitator&spin issues (Washer Repair)
by Guest 1/16/2022 10:55:31 AM(UTC)
Agitator barely moves (Washer Repair)
by Xicano69 10/25/2021 7:16:40 PM(UTC)
Grinding with working agitator. (Washer Repair)
by Guest 9/23/2021 1:10:18 PM(UTC)
Whirlpool washer agitator working but with grinding noise (Washer Repair)
by Guest 9/23/2021 1:06:39 PM(UTC)
Agitator Stuck! Can't get it out. (Washer Repair)
by TWash2 6/16/2021 3:22:28 PM(UTC)
2 Pages<12
