carolb4
#1 Posted : Wednesday, August 26, 2009 8:07:02 AM(UTC)
carolb4
It is a Badger disposal. I do not feel anything in the disposal and I don't believe it is jammed because when I turn it on it starts grinding with a really loud clanging. Sounds like a blade has come loose and is tossing around in there. Suggestions?
#2 Posted : Wednesday, August 26, 2009 3:10:08 PM(UTC)
Pull the garbage disposer out and inspect the blades. If it came loose - it is not repairable.
