I have the same problem. GE Model #GSH25KGPABB. I just replaced the solenoid and it still does not click or dispense ice. I also replaced the front panel with a new one that I already had and that didn't help. Any other ideas. How can I test to see if the new solenoid is bad?
Does the gate in the ice chute open when you push the lever? Does the water dispenser work?
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Does the gate in the ice chute open when you push the lever? Does the water dispenser work?
Gene. The flap in the ice chute in the door opens however the gate attached to the metal rod does not open the gate that is supposed to allow the cubes to clear the grinders. The water dispenser works and crushed ice works when both the crushed ice button is depressed and when the cubed ice button is depressed. With the door open and the door button depressed and cubed ice selected the solenoid does not activate. I tested the solenoid resistance and got 35 ohms. Thanks for taking the time to assist me.
Thanks Gene, tested and found NO voltage at the solenoid. I guess I'll get the main control board. Thanks for the assistance.
