joencoll
#1 Posted : Friday, February 17, 2012 3:39:46 PM(UTC)
joencoll
I am getting an upside down F followed by an E, manual says it is a Tempature Sensor.. What is the part or parts required to fix it? :confused:
rhornecker
#2 Posted : Tuesday, August 28, 2018 6:51:14 AM(UTC)
rhornecker
I have a Samsung WF350 ANR XAA 03, had the same code. Up side down F and E repair code. I replace the washer thermistor DC9010128H, and the same code appear again. After a few months of replacing different parts. I notice the two wires that connect the thermistor to the drum. The white wire came loose from the connector. Splice the wire and connected back and problem solve.
