You are welcome. No, it does not.
I just installed new defrost timer and turned on the ref. and it does not start.Is it a bad part?What is wrong now?
The timer could be in the defrost cycle. Turn it till it clicks and see if everything starts then.
Or just wait about 30 minutes.
Gene and Woodchuckle, Thanks a lot, I tuned it and it works .
We are glad you were able to fix it.
The fresh food thermostat was turned from 5 to 7 to obtain 38 deg.F. temp.The freezer thermostat was turned from 5 to 6 yet the temp is 18 to 20 deg.F.I understand that the freezer temp should be 0 deg..F. to 5.deg. F. Gene and Woodchuckle your input is required to resolve hopefully this last problem.Thanks in advance.
Remove the evaporator cover and check how is the evaporator covered with snow. If there is not 100% of thin snow then most likely there is a problem with the sealed system. It can be low on Freon. It can be a restriction in the system. In such situation it has to be tested by a certified technician.
Gene, Thanks for your quick response.I will check out ASAP.
Gene, you are right.There is no snow around the evaporator coil.The ice maker works the compressor is very hot and I can feel the heat by simply touching the top panel cover.What can be the reason for the compressor getting so hot?Thanks
