Originally Posted by: Gene  One more test: You need someone else to help you. With the door open, hold the door switch pushed in, push the start switch and turn the drum manually. See if it would start or any noises will come from the motor. If nothing happened, disassemble the dryer and check all motor windings for continuity according to the wiring diagram. Good luck. Gene.
Now, what is the answer based on me having successfully started the drum manually?
johnsob7,
What was the original problem?
What is the complete model number of the dryer?
