janh8
#1 Posted : Sunday, January 16, 2011 10:05:05 AM(UTC)
janh8
I have to do 2 extra spins on high after the washer is finished, before I can put the clothes in the dryer. Otherwise the dryer takes forever to dry. Thought I had a dryer problem. Several months ago the washer started making a loud/squeaking noise when it's agitating. It doesn't always make this noise, but most of the time it does. I have to wash just about everything on low as high seems to agitate real fast & hard. Not good for the clothes. I noticed some oil under the washer some months ago when I moved it to clean. (cleaned out the dryer hose & vent thinking something was wrong with the dryer) Figured oil was not a good sign. Washer seems to clean the clothes just fine. I want to find out what all is wrong, so my husband can fix it. Thanks!
sidfink43
#2 Posted : Wednesday, January 19, 2011 5:39:47 AM(UTC)
sidfink43
The oil means the seal on your transmission has failed, and now your transmission is failing. You can replace it, it is not a difficult job and the cost is reasonable, but given the aggressive pricing of new machines you should consider replacing the washer.
