3 Pages<123
Dblboinger
#21 Posted : Saturday, November 2, 2013 6:53:33 PM(UTC)
Dblboinger
It also appears that the CCU has numerous part numbers. So far I have found 4 that appear to be compatible with this machine (W10246302, W10205976, W10205839 and W10525356). Can you verify this is correct?
Joe / APP Team
#22 Posted : Monday, November 4, 2013 5:23:58 AM(UTC)
Joe / APP Team
Originally Posted by: Dblboinger Go to Quoted Post
Joe...did you mean 9-10k ohms? That is what my sensor measures and I can se the value change if you submerge it in warm (reading decreases) or cold water (reading increases).
Dblboinger, You're correct, I guess I forgot to add the K ohms to the previous post. Your resistance readings in general are correct, the resistance should increase as the water temperature is cool, and decrease as the water temperature increases. Now you need to do the same test at the wire harness connector at the TH2 terminal on the CCU. (You may need to insert a metal paper clip, large needle or pin into the connector to test the readings at the harness connector. If you get the same results, this will tell you the sensor and wire harness are operating properly, and you will need the CCU
W10525356
Part number: AP5781703
3 Pages<123
