:) Originally Posted by: richappy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Your computer may be stuck in error mode,to reset, open door, within 3 seconds hit hi temp scrub,then energy saver buttons, repeat this, then close and latch door,then press cancel button. This should fix it, if no hi temp scrub, push similar button. If this fails, one of your keypad buttons is jammed. Try to unjam it. Unplug keypad, if this fixes it, you need a new keypad. Usually, the clean light will flash in 7 flash intervals, if not, try the keypad unplug routine above. You were correct - it worked!!!! - except on my Whirlpool model DU1055XTPQ3 it was the combination of hi temp wash & heated dry buttons that unstuck mine. Thanks for the quick fix. I knew it was a code and had tried several combinations of buttons, just not in that particular sequence- don't believe I would have ever ramdomly found it without your help- Thanks!!
Thank you all so much for posting what you do! Saved me at least $200 to fix the same problem with my dishwasher! My backwoods location tags on $75 -$100 just to set a date for repair. I have used this site before with awesome results then as well. Again, Thank you, in this time of money being short, this was a true blessing.
