Turn table turns, but sounds mlike it is gringing stones, is the motor an easy repair? I am comfortable in working on it.
The problem is a bad turntable motor. No doubt about it. Remove the screws around the bottom panel and remove the panel. Remove the glass tray and the coupler. The motor secured with the two screws. - The part number for the turntable motor is AP2024962 Gene.
