Originally Posted by: mikew58 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) In addition to a Whirlpool gas range model #SF362LXST, I have a similar situation that the oven does not heat. I ohmed the valves out. The broiler solenoid ohms out at 197 and the oven is open. Both igniters work. Here's the strange thing: there was advice from one of the Technicians that if one of the solenoids was open, then neither one could work. On my oven the broiler still works, but the oven does not. Do you still think it's the gas/regulator valve that's the problem? Mike Mike, Per the test results you posted the gas valve/regulator is bad. No doubt about it. Is there something else wrong? We do not know yet. Replace this part first and hopefully it will solve the problem. Gene.
Gene,
I replaced the faulty gas regulator valve and that took care of the problem. I ordered the new one from this site and it arrived in two days. But, I do want to say that my broiler alone still worked with the faulty one, which contradicts what was said before about when one goes out, the other one won't work either. Thanks for all your help. I highly recommend the service this website provides.
Mike
You are welcome Mike. I'm glad you were able to fix it.
Thank you for the feed back and sharing your repair with us.
What voltage operates the gas valve? I'm having a similar issue. I get 120vac to gnd out of the touchpad board output to both the oven and broiler. But I only get an output out of the "ignitor" board on broiler and not oven. I get 2 pulses ov about 25 v then nothing. At first I thought it was the ignitor board because that seems to control the power to the gas valve, but after reading this thread, I'm leaning toward the valveas it seems to be the most common. This unit's valve has already been replaced twice I've been told!
You may want to check the gas valve/regulator solenoids as described on the first page in this thread.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi Jim, Remove the bottom drawer. Locate the gas valve/regulator with three electrical solenoids terminals on the back of the range. The middle terminal is Common, the upper terminal is Broil and the bottom terminal is Bake. Mark all wires and remove them from the terminals. Check between each solenoid for 216 Ohms resistance (Broil to Common and Bake to Common). If one of the solenoid is defective, neither one will operate and the gas valve/regulator has to be replaced. - The part number for the gas valve/regulator is AP3866825 If there is nothing wrong, post the results and we'll proceed with further diagnosis. Gene. Hi Gene, Both solenoids checked out at 216 ohms. So it's not gas valve regulator. What do I do next?
Originally Posted by: tomjoy1 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi Gene, Both solenoids checked out at 216 ohms. So it's not gas valve regulator. What do I do next? What is the complete model number of the range? What exactly is the problem? Gene.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) What is the complete model number of the range?
Gene. Hi Gene, Model of Whirlpool Gas oven is SF362LXSQ0 bot 8/4/06. The problem is that the oven won't turn on. When I turned on there was no click. Tried the broiler, it clicks but then does not turn on either. The stove top burners work fine, clock, controls all work fine and have never had a problem. Put in new oven igniter. Still no click. Checked continuity in old oven igniter and it was fine. Checked the continuity in the oven and broiler silenoid as you had instructed, and they both checked out at 216 ohms, just as you had said they would. So gas valve/regulator is fine. Now I need to know how to proceed from here. I'm thinking it's the spark module. What do you think? If it's that, how do I test to make sure that it's the problem? Thanks for your help. Tom
Tom, Check for 120 VAC between the wires connected to the J1-6 & J1-4 (at least one wire should be disconnected) at the spark module while the control calls for Bake. If there is proper voltage, replace the spark module. If the reading is incorrect, replace the control board. - The spark module Part number: AP3672576
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Tom, Check for 120 VAC between the wires connected to the J1-6 & J1-4 (at least one wire should be disconnected) at the spark module while the control calls for Bake. If there is proper voltage, replace the spark module. If the reading is incorrect, replace the control board. - The spark module Part number: AP3672576
Hi Gene, I replaced spark module, and oven still didn't work. Then I replaced the control board, and the oven still didn't work. What else could it be? Thanks for your help. Tom
