2 Pages<12
Guest
#11 Posted : Sunday, April 9, 2023 10:26:02 PM(UTC)
Guest
Armored and Strong Technical Services L.L.C is a leading property maintenance and renovation company in the United Arab Emirates, the best home maintenance company in Dubai. Our experienced team and extraordinary services confidently exceed our clients’ expectations. Our principal areas of business include, but are not limited to a wide range of property maintenance, facility management, and property renovation, interior design, and fit-out. Here, at Armored and Strong, we have molded a mission to customize, design, and execute a service that is timely, reliable, sustainable, cost-effective, and that guarantees quality for our customers.
Guest
#12 Posted : Wednesday, August 30, 2023 4:56:27 PM(UTC)
Guest
I've been going crazy with my GE top load machine sometimes it will drain perfectly and sometimes not I've had service people here no one could figure out what the problem was I changed the belt I put new water inlet valves in I checked the water level sensor and finally I purchased a new drain pump during the process of removing the old drain pump I realized that the amp connect plug was very loose apparently what was happening is with all the jiggling and shaking and vibration the plug would come loose enough so that the drain pump would sometimes WUvgyS3nnot drain I put the new pump in made sure that the plug was tight and twisted slightly the amp terminals so that they would make good contact and not loosen and then I used a nylon tie strap to hold the plug secure now it's training fine all the time
Extension hose for GE washing machine GFW850SPNRS (Washer Repair)
by Guest 3/17/2023 9:53:53 PM(UTC)
GE Washing machine water level problem (Washer Repair)
by Guest 12/3/2022 12:53:02 AM(UTC)
GE washing machine leaking help (Washer Repair)
by HotCarl919 6/18/2022 8:12:16 AM(UTC)
GE Washing Machine no lights and will not turn on sometimes (Washer Repair)
by Denver714 3/11/2021 6:58:31 AM(UTC)
Before you replace that GE washing machine control board... (Washer Repair)
by GEfixerupper 10/11/2020 6:25:53 PM(UTC)
GE washing machine wash cycle issue (Washer Repair)
by MrLuke 4/23/2020 11:00:59 AM(UTC)
GE washing machine power goes on and off (Washer Repair)
by momage333 3/29/2020 6:03:57 AM(UTC)
GE Washing machine deep fill (Washer Repair)
by tech07 5/12/2019 5:10:57 AM(UTC)
Help on GE washing machine (model WBB4500E1WW) (Washer Repair)
by charley807 2/5/2019 9:26:42 AM(UTC)
GE Washing Machine Drips When Off (Washer Repair)
by kevin1boyd 5/7/2017 5:48:33 AM(UTC)
GE Washing Machine freezes and locks up (Washer Repair)
by Swilly 8/24/2016 1:39:40 PM(UTC)
GE washing machine wont drain or spin but agitates (Washer Repair)
by Billybrokege 5/14/2015 2:26:58 PM(UTC)
ge washing machine help (Washer Repair)
by dnpro02 3/19/2015 7:57:02 PM(UTC)
GE Washing Machine Making Crazy Noise and Electrical Smell (Washer Repair)
by TripleDigitRide 6/21/2014 8:05:46 AM(UTC)
GE Washing machine is overflowing on super setting only (Washer Repair)
by Ctomanec 3/29/2014 9:53:09 AM(UTC)
2 Pages<12
