I recommed to use GoTech Appliance Repairs for fast and high-quality assistance. I used their services few times and this is really a reliable assistant in the repair of household appliances, including washer
Here is good advice for your problem
You can once try ... Moved to Dishwasher repair section and made it a "sticky".You can help from near by appliance professional.
I have been getting a special nut busting solution on it for three 2 days now so that will probably help. Take a sharp wooden chisel and gently pound on the top edge of the impeller near the screw. Crack it away from the shaft , then apply sharp oil to the screw.
