3 Pages<123>
Reenie50
#11 Posted : Tuesday, August 19, 2008 9:02:11 AM(UTC)
Reenie50
I have another question when I push in the knob and it wants to stats it justs quits and then I have to wait a few mintues and then push the knob in again
Reenie50
#12 Posted : Tuesday, August 19, 2008 9:03:20 AM(UTC)
Reenie50
there does not seems to be anything in the blower I went down and checked
abadfish66
#13 Posted : Tuesday, August 19, 2008 9:11:20 AM(UTC)
abadfish66
You should have no play in the rollers. The motor is tripping on the overload protector, once it is tripped it has tp cool before it will start again. If everything is checking out ok, then it looks like the motor may need replacing, but find out where the rubbing is coming from.
Reenie50
#14 Posted : Tuesday, August 19, 2008 9:19:20 AM(UTC)
Reenie50
what if it just full of lint
abadfish66
#15 Posted : Tuesday, August 19, 2008 9:21:58 AM(UTC)
abadfish66
The motor could be gummed up with lint clean motor if there is lots of lint and see what happens
Reenie50
#16 Posted : Tuesday, August 19, 2008 9:23:21 AM(UTC)
Reenie50
which is the fast and easiest way to get to the motor
Reenie50
#17 Posted : Tuesday, August 19, 2008 9:23:51 AM(UTC)
Reenie50
can I take the back off the dryer
abadfish66
#18 Posted : Tuesday, August 19, 2008 10:03:38 AM(UTC)
abadfish66
No, don't take the back off, you need to remove the belt, and pull the drum out
Reenie50
#19 Posted : Tuesday, August 19, 2008 10:33:01 AM(UTC)
Reenie50
I removed the drum and I found a looks like a clip it is a half moon but I dont know where it goes it was laying in the bottom of the dryer
abadfish66
#20 Posted : Tuesday, August 19, 2008 10:42:03 AM(UTC)
abadfish66
If it was this----> Model PYE2300AYW
That clip goes on the shaft that the wheel is attached to to keep it from falling of the shaft
dryier drum wont turn when clothes are put in, with cloths te dryier will run (Dryer Repair)
by jklimuszka 12/7/2012 3:25:03 AM(UTC)
drum wont turn with a normal load (Dryer Repair)
by fred bruning 4/25/2012 10:42:17 AM(UTC)
LG Front Load-LE Code- Drum wont turn (Washer Repair)
by sleddoc 5/3/2011 5:51:12 AM(UTC)
gas dryer drum wont turn (Dryer Repair)
by mpeccleston 10/24/2010 7:54:23 AM(UTC)
Front Loader drum wont turn (Washer Repair)
by jtoddrn 4/10/2010 8:14:11 AM(UTC)
admiral dryer..drum wont turn (Dryer Repair)
by PJfuture 11/25/2009 6:47:13 AM(UTC)
Drum wont turn (Dryer Repair)
by beachboy 5/5/2009 1:20:56 PM(UTC)
3 Pages<123>
