Hello:) :
My washer was exposed to 220 Volt by mistake (I live now overseas, but I got my neptune set back in Pittsburgh, PA), so knowing that the washer was using double the voltage that needs what parts do you think are broken?
The clothes in the end are very clean but very wet, the drum moves but I don't heard the final spin, sometimes the cycle stops and I have to open and close the door and push start again in order to finish the cycle.
I have been using my washer like this but I want to try to repair if possible. I need the steps, what parts do I need to replace. Last May you guys helped me with fixing my Maytag Gas Dryer (same problem, exposed to 220 Vol by mistake) and is working fine now, Thanks.
Any help would be appreciated.
Thank you in advance.
Cielo Castillo
Cielo Castillo Update: I took a look at he Control board and the R-11 Resistor is burnt up; I read some other similar problems and they advice to change the control board and other guy advice to replace just the R-11 resistor along with the associated Q-6 triode, also the Wax motor. I want to try the less expensive repair first, since a friend will bring me the parts overseas and it will be best if the parts are small in size and in cost. Please guide me with the parts numbers. Thanks, Cielo
