teddy
#1 Posted : Monday, June 8, 2009 7:31:24 AM(UTC)
teddy
the washing machine will only was on gentle cycle not normal, what could be the cause of the trouble
richappy
#2 Posted : Tuesday, June 9, 2009 7:04:06 AM(UTC)
richappy
You have either burnt contacts in the timer, or a bad motor. Put the timer in normal wash, pull the cover off the timer, and check the contacts that should be closed, you will probably find burnt ones. If you need a timer, call this parts site for the correct part #, your model # does'nt work.
Dishwasher not cycling (Dishwasher Repair)
by Troy Nothwang 10/2/2013 6:33:11 AM(UTC)
whirlpool washer not cycling right (Washer Repair)
by broadwayjoe9 6/2/2013 1:53:49 PM(UTC)
Washer not cycling properly (Washer Repair)
by Helplease 3/5/2013 1:13:36 PM(UTC)
Washer not cycling (Washer Repair)
by jwilcken 4/29/2011 8:00:38 AM(UTC)
by EvanP 2/23/2010 9:15:33 AM(UTC)
