I have a Samsung dryer and I noticed it was blowing cold air. Checked the vent and it was clear. Put a new coil in and then the dryer blew way to hot. The drum was to hot to touch. So then I put in a thermostat. Now the dryer starts and the cycle starts at 45 minutes but at 43 minutes it goes straight to 1 minute and turns off. My mind is shot on what is going on with this thing. I did buy a thermistor when I got the thermostat. Should I try that next? I'm out of ideas...thanks!
So it works on time selection only. Not working on normal function..
